terminal style ammeter hookup ?
rjboy54
12-24-2006 10:49:33
i just installed a new wiring harness from Tractor Supply and I had to get a new ammeter in the terminal style.
I have one wire closest to steering column going to the bottom of the block and I have tried to run one to the battery side of the starter and still no hand movement.
Anyone got any suggestions ?
6 volt positive ground, 1949 8N
Thanks,
Johnny
Bruce (VA)
12-24-2006 10:59:40
 Re: terminal style ammeter hookup ? in reply to rjboy54, 12-24-2006 10:49:33
One wire goes from the solinoid to the ammeter, the other goes from the lug on the terminal block that has the ignition switch wire connected to it. Assuming, of course, that nobody has screwed up the wiring on the tractor! Hook it up like that; if the meter reads backwards, reverse the wires or stand on your head to read it. :)
rjboy54
12-25-2006 05:21:09
 Re: terminal style ammeter hookup ? in reply to Bruce (VA), 12-24-2006 10:59:40
Thanks Bruce,
now the solinoid you refer to is the small wire
on the starter soliniod that goes back to the starter button ?
Thanks,
Johnny
Bruce (VA)
12-25-2006 15:25:35
 Re: terminal style ammeter hookup ? in reply to rjboy54, 12-25-2006 05:21:09
No..... the wire from the starter thumb switch goes to the center post of the solinoid, the little tiny post that faces the block. The wire I'm refering to is attached to the battery cable post of the solinoid. It should have the cable from the negative side of the battery on it, along w/ the wire to the ammeter.
rjboy54
12-26-2006 04:54:34
 Re: terminal style ammeter hookup ? in reply to Bruce (VA), 12-25-2006 15:25:35
ok , thanks, i think i can figure it out from here.
Johnny
rjboy54
12-26-2006 15:25:18
 Re: terminal style ammeter hookup ? in reply to rjboy54, 12-26-2006 04:54:34
OK, I"ve tried it several ways and it will not work any way I"ve tried so I went back to the wire through the back of the original and it works great.
It doesn"t look very good but it works,,,,, ,,thanks for all of the help.
Johnny
