Now that the Christmas "rush" is over, I got to work out in the shop/shed on an engine that I bought w/tractor last spring. I followed the advice of board members and welded 4 beads down the length of each sleeve to shrink them for easy removal. The only time I have removed sleeves previously was years ago in my Farmall H, and I used my lathe to make a stepped disc to fit the bottom of the sleeve and yet clear the block bore to pull the sleeves up and out. I broke them free by dropping some dry ice in each hole after the puller was set in place. They were a tough pull, but nothing was damaged.Now on to the 8N block, and the weld removal method. 1st off, mine does not have the .090 sleeves, but something thinner, as the pistons were marked .083, I think this was the piston used in the Merc flathead engine. I set the wire feed welder to give ~100 amps and kept the nozzle moving side to side to give almost 1/2" wide bead. I was concerned about the possibility of burning through the sleeve and zapping the block. In the end, I didn't zap the block, but sure got close. After the sleeves were out, they sure had curdled metal on the outside surface of the sleeve where each bead was laid. I would not want to try this method with a stick welder, as they can cut in for much deeper penetration. When I started, the block was about 30 deg F, and was warm to the touch (but not HOT) when finished. I could hear the metal "talking" and cracking as it cooled. As I was welding on the #2 sleeve, some liquid began oozing out between the outside of sleeve and block bore, not much, but was noticable. I sprayed each sleeve w/WD40 as they cooled and then took a piece of 5/8" soft steel rod as a punch and tapped easily on the bottom edge of each sleeve until all 4 were out. None fell out, but came with easy tapping w/ the punch. At first, I thought that I could tap the sleeves out the bottom...> wrong! They interfere with the main bearing journals. But it was easy to tap them the other way and out the top. Now I see a 1.25" long crack in the #2 bore that is parallel to the top surface of the block about 1" below the top deck. The bore metal is slightly pushed into the block. Did I create this crack with the heat of the bead on the sleeve? I would guess that if I cracked it from the welding, it would not be pushed in, and would run vertically, somewhat following the weld bead heat. Did the slight liquid that formed at the block/bore line while welding indicate previous antifreeze seepage through this crack? What to do now? I think that I can still use this block. I know that I need to mike the bore to be sure the new sleeves will fit. Assuming that is OK, I remember reading that some of you have recommended a sleeve sealer product. Will the standard .090 thick sleeve have sufficient heat transfer at a spot where the block bore is not tight against it? Am I going to have a troubled engine if I proceed to use this block? I'd like to post a photo, but I am critically low on the learning curve as to how....down where the curve is flat against the x-axis. Sorry this is so long. Paul in MN
