Radiator Mounting Bolts
Rod From IL
12-30-2006 19:15:56
Well the last snow we had I plowed out my fair share drive ways. On the way home I was running wide open ( Norm not a problem at a woping 14mph) but I hit a chunk of ice and the front end shook so much the fan hit the Radiator. And you gessed it. Blew fluid all over the front mount and I was Dead in the snow. Well I pulled off the Radiator and took it to the Radiator shop and they fixed it up better then before. But now I am trying to get it back on. On the bottom of the Radiator there is a slot for the bolts but what size and shape are they. any help would be great. have a Awsome New year
Henry M
12-31-2006 05:36:28
 Re: Radiator Mounting Bolts in reply to Rod From IL, 12-30-2006 19:15:56
Mine had just regular old course thread charriabe bolts in it when I took it apart. They been there a long time
kelsh
12-30-2006 19:57:06
I just replaced them on mine and they are 7/16 fine thread carage bolts 1 1/2 long.
wayne2
12-30-2006 19:22:13
Carriage Bolts-there is probably a pair in your shop!!!
wayne2
12-30-2006 19:22:09
jspencer
12-30-2006 19:38:08
 Re: Radiator Mounting Bolts in reply to wayne2, 12-30-2006 19:22:09
I think they are 5/16 but not sure. The square under the head of the carriage bolts should match the slot in the bottom of radiator so they don"t turn when installing or loosening them.
You need a thick gaket, I would use 1/8" thick rubber washer between radiator and mounting surface of tractor to protect radiator.
Common sense will help in determining size of bolt. I am sorry but someone else hopefully will tell you what size to use.
