Order Ford 8N Parts Online
Timing a ford 8n tractor 1948
Paul Crum
01-03-2007 13:44:30
can anyone tell me how to change the timing on a 1948 8n tractor with front dist. ?
Dan NYC
01-03-2007 20:28:07
 Re: Timing a ford 8n tractor 1948 in reply to Paul Crum, 01-03-2007 13:44:30
The "timing" adjustment on the front mounts is when you set the point that the contacts just start to open. You will have to look at the manual there are photos showing the measurement to take to adjust this. There is a screw on the outside of the housing that will allow you to adjust the timing to their desired point. Hth
Dan---nyc
Bob Harvey
01-03-2007 17:44:50
Answer; as below, Nope. These are VERY basic engines for two reasons: 1. Mr. Ford ensured that the costs be kept down (wise) 2.That the new (switched from mules/horses farmers) would have no problems. Engine timing was left to the simple system of 'just put the parts together, as manufactured', and voila! (pardon the French)the suckers WILL work !!
ZANE
01-03-2007 16:18:14
Unless you plan to race the tractor or something like that it is not necessary to "time" the N tractor ignition with front mounted distributor. Just set the points at .015 and put the distributor back on the tractor. You can't put it on wrong without breaking something!
Zane
Third Party Image
Tex - Driftwood, TX
01-03-2007 15:16:43
I found this the other day. here's the link with diagrams.
http://www.tntwebdevelopment.com/tff/timing.htm
Ross Pugh(NC)
01-03-2007 14:43:23
Pg. 56-59 of the FO-4 Manual tells ye all ye need to know. Good Luck!!!
OH Boy
01-03-2007 13:51:26
You really need to see the manual for this, it has pictures. It is simple when you see the pictures, but difficult to describe in words.
I time mine with the distributor off the tractor using a little test light to show when the points open and close.
