HOW BEST TO REMOVE STEERING WHEEL?
8N24342
01-04-2007 09:40:01
Bought a new steering wheel for my 1948 8N. What is the BEST way to remove the old one?
8N24342
01-04-2007 21:06:13
 Re: HOW BEST TO REMOVE STEERING WHEEL? in reply to 8N24342, 01-04-2007 09:40:01
Thanks to all. I will use your advice and let you all know how it went! PS: Great Forum
Dunk
01-04-2007 17:44:25
I've been putting this off.....
And this has been quite a few years back.
Mine got hard to turn one way, but easy the other, I man handled her, till the steering wheel and shaft came all the way out of the column while I was running her (reminded me of the three stooges).
I had this dilemma with the wheel still being seemingly welded to the shaft, and it did NOT want to co-operate.
I took the nut and washer off, kept her sprayed with penetrating stuff for a couple of days, after I finally got her back in the shop going in circles in only one direction.
Put the acorn nut back on and beat the dayum thang, after so long of a time till she finally had all the threads pretty much destroyed.
But I did get er off.
I done the rest of the taking apart and cleaning of the steering sector and replacing the sealing stuff, with new parts, I didn't change the bushings.
Got her all back together and the steering wheel back on, put on the washer and the nut, and I couldn't get the nut to catch a thread no matter what I tried...
A 2lb hammer finally fixed that issue.
Maybe it will last the rest of my life.
It must have been one of my slow days, I have a torch and know how to use it.
Sometimes, sometimes...
I just seem to have these brain farts...
Stumpalump
01-04-2007 17:43:21
I think Dell is still having hard drive problems but I remember him saying that these things pop off all at once sending you and the wheel over the back of the tractor. Put the acorn nut back on a few threads befor you yank on it to stop the wheel from popping off to fast.
`Bernie in MA
01-04-2007 17:33:38
I used a 3-jaw puller. I put a small clevis on each spoke to change them 90* so the puller could hook on.
Cliff (VA)
01-04-2007 13:54:57
I just did mine Saturday. It will not feel like it is moving until it pops off. I could see the line on the outer shaft from the PB blaster and that was the only way I could tell it was moving.
Good Luck,
Cliff (VA)
old
01-04-2007 10:49:46
What the others have said and also some times alittle heat helps, just don't go over board if you use heat.
Empennage
01-04-2007 10:33:59
Take the acorn nut off and the washer. Spray the shaft with some penetrating oil, put the washer and acorn nut on loosely ( just the first 2 to 3 threads) then climb aboard your tractor and grab a hold of your steering wheel and pull up on it hard one side at a time back and forth. If you feel you need to, whack the top of the acorn nut lightly while you wiggle the wheel.
Gregg E
01-04-2007 10:16:09
I removed mine be taking odd the nut and rocking it back and forth, until it broke free, I did not have to hit it with a hammer. Just keep working it, I will come loose
Dave from Texas
01-04-2007 09:50:23
I losen the bolt, protect the shaft threads the best I can, pry up on the old steering wheel and at the same time hit the shaft with a heavy hammer. It is hard to use a puller because there is nothing good to clamp to. This works for fly wheels but you have to be careful not to damage the fly wheel.
