Order Ford 8N Parts Online
8N
R.A. JOHNSON
01-07-2007 08:08:29
I HAVE AN 1951 8N WITH LOW & HIGH RANGE TRANSMISSION. IS THIS COMMON ON A 8N.
old
01-07-2007 09:17:03
 Re: 8N in reply to R.A. JOHNSON, 01-07-2007 08:08:29
Just to add to gaspumps words. That h pattern he talks about is correct but he didn't tell you to turn the h upside down for it to work. To find out you take your shifter and put it in nutral and then pull out on it to the left. If it comes out about a 1/2 inch then you pull up and that means you have a sherman comb which gives you under drive over drive and standard drive gears, or in other words 12 forward speeds
Gaspump
01-07-2007 08:15:31
An option installed by the distributor or dealer, not common, not rare. By 1951 most were over, under and direct units with the small "h" pattern.
