Transmission Hydralic Fluid
Arlen
01-10-2007 11:23:29
I have a 1948 8N Ford and I need to buy some transmission hydralic fluid but I don't know the number I need. Would appreciate any help I can Get.
Thanks Arlen
Stumpalump
01-10-2007 12:25:24
 Copied from Bruces tips in reply to Arlen, 01-10-2007 11:23:29
The N tractors have a common sump for the rear end, hydraulic pump and transmission. There are three drain plugs under the tractor and one filler cap behind the gear shift. To change the fluid, start by removing the pipe plug under the rear end and move forward to the hydraulic pump and then the transmission. Use only Ford MC-134D hydraulic oil or 90w mineral oil. The modern equivalent of 90w mineral oil is TSC Traveller brand GL-1 or NAPA part number 65-205.
To add just the right amount of hydraulic fluid, remove the bottom bolt from the inspection plate; unless you just cleaned out the sludge in the pump base, it will only take about 4 ¾ gallons (not 5) of hydraulic oil. When the oil leaks out of the bolt hole, it has enough in it. Any more fluid will leak past the seals and onto the brakes. Mark you dipstick accordingly
souNdguy
01-10-2007 12:08:40
 Re: Transmission Hydralic Fluid in reply to Arlen, 01-10-2007 11:23:29
If you like the thin stuff.. then use any UTF compatible with NH M2C134D
Or use a mineral gear oil, 90wt.. in gl1 or gl3.
thanks
Soundguy
CT8N
01-10-2007 11:45:40
Try this link
http://www.ytmag.com/cgi-bin/viewit.cgi?bd=nboard&th=570023
