flywheel ring gear
RAGinTn.
01-14-2007 11:53:52
Ok guys I been readin all your posts on the ring gear and you say it's easy but mine just wont go on ive heated it til it was blue with a tourch and my heat crown melted and it wouldn't go on, so i tried the oven trick some of yall talked about I cooked that thing fer 6 hrs tryin it every hour and it still didn't go I'll probably take it to the machine shop monday unless you got any other tricks
HowieNJ
01-14-2007 17:42:32
 Re: flywheel ring gear in reply to RAGinTn., 01-14-2007 11:53:52
thanks for the great info. there will be a test on this next weekend.i have many projects to do and this is one of them thanks again.
Rusty48ford
01-14-2007 15:07:11
Fire up the barbeque grill and let it cook for an hour or so. Drink beer. Set the flywheel on two pieces of railroad iron, center the hot gear and tap it on. May take another buddy to keep it centered and don"t get too heavy with the hammer. Drink more beer and admire the job. Ford says to cool it quick to retain temper in the teeth and shrink the ring to the flywheel. Drink more beer.
Hobo,NC
01-14-2007 16:57:40
 Re: flywheel ring gear in reply to Rusty48ford, 01-14-2007 15:07:11
One more thang I never herd "Ford says to cool it quick to retain temper" New'in on me or never read it, I let'em cool naturaly you kin squize a nutter beer in if you are a slow drinker
Ross Pugh(NC)
01-15-2007 06:08:44
 Re: flywheel ring gear /Hey, Hobo-Read FO-4 Manual in reply to Hobo,NC, 01-14-2007 16:57:40
Hobo, read pg.36, Section 44 in FO-4 Manual. It says " Quickly install the heated ring gear on the flywheel, then quench the gear teeth with water to obtain a shrink fit." This says nothing about the temper. Also , I agree it is not necessary to add water to shrink fit, just let it cool first before moving, right?
Hobo,NC
01-14-2007 16:54:49
I am always open to ideas and often wonder about the grill. My grill will git 700 plus but most only do 425 or so. I do use the grill to heat up differential ring gears before I install’em on the carrier, makes em smell like chicken. I sit it at 400 fer 30min. on the diff deal. The last few flywheel ring gears expanded a mite quick fer me, I am sure it wuz not the heat and the steel. I do not like to tap one on I soon as see it fall on. I kin not say fer sure it makes enny difference cuzz I have never had a problem either way.
Hobo,NC
01-14-2007 12:19:44
poke here
ZANE
01-14-2007 14:54:51
 Re: flywheel ring gear in reply to Hobo,NC, 01-14-2007 12:19:44
Neat Hobo! The guy may be trying to heat it with a propane torch????
Zane
Third Party Image
Hobo,NC
01-14-2007 15:55:15
 Re: flywheel ring gear in reply to ZANE, 01-14-2007 14:54:51
I have a friend that tells me he props up the ring gear and pours fuel oil around the circle on the ground and lites it up once it burns down he izz able to install the ring gear. I ask why fuel oil and he said it burns longer and has more BTU’s Dunno but he does come up wif sum neat ideas and a rite smart guy. I invited’em over fer sum chick’in wings cooked on a grill today cuzz I injoy hiz take on how to do things. He operates a saw mill fer a living and always has sum’in tore up and figgers out a way to make replacement parts fer the olds mill. If you ever come into my shop all the wire’in izz run in condurent, He did it all. He took the time to teach my son how to do all the crazy bends and such. He’s a born teacher with a nac fer it. I would never have the patients to do that.
ZANE
01-15-2007 05:09:47
 Re: flywheel ring gear in reply to Hobo,NC, 01-14-2007 15:55:15
Long time ago on another planet I once watched an old mechanic pour some gasoline into the back side of an old car wheel then lay a ring gear on the wheel and light the gasoline. When it had burned for a few minutes he picked it up with a pair of common pliers. (Vice Grips had not been invented!) (I'm old!) He dropped the ring gear over the flywheel and it clamped right onto it. Picked the flywheel up and took it back in the shop!
He's been dead for 50 years.
Zane
Third Party Image
RAGinTn.
01-15-2007 08:44:16
 Re: flywheel ring gear in reply to ZANE, 01-15-2007 05:09:47
well I took it to a shop to get it done. and now I wait. I tried an oxy acetalyne setup 1st to get it heated up and no luck I cooked that thing fer 6 hrs. at 400 in the oven and it wouldn't go so now its sumone elses turn
