uhhh. where does it go
RAGinTn.
01-15-2007 08:56:01
Ok guys one last thing I got a small threaded plug looks like the plugs at either end of the oil gally which I checked and know are thair and this little plug has red paint on the end so makes me think it goes on the outside of the engine sumwhere but I dont see where. the engine is on a hoist all assembled accept the flywheel and head. its exactly the same as the plug fer the oil gally but that aint where it goes. anyone got any ideas. Thankyou again fer all your help!!!
RAGinTn.
01-16-2007 21:55:54
 Re: uhhh. where does it go in reply to RAGinTn., 01-15-2007 08:56:01
ok the oil gally is a tube that runs the length of the engin along side the cam and delivers oil to all the moving parts and haz a plug at either end sloted for a flat head screwdriver im not sure of the exact size but im guessin its bout a 5/16 fine theread. not the filter housin plug but good guess. this plug would screw in and sit flush with the wherever it goes. I did check and it is not the plug fer the oil gally, it has red paint on the end so it must go outside the engine sumware
Drmeatman
01-15-2007 17:32:08
I am not sure by your discription but could you be refering to the drain plug on the bottom of the filter canister? It's small and it's a plug.
old9
01-15-2007 17:29:12
What pipe size? 1/4, 1/8, 1/2, or outside diameter? in inches.
Ross Pugh(NC)
01-15-2007 15:35:08
What are ye callin' the oil gally plugs. No idea what ye are refering to. Can ye give a better description?
RAGinTn.
01-15-2007 12:28:24
had a petcock in thair, and its a different size but thanks for the reply
Danny in CO
01-15-2007 09:14:34
Did you have the plug where the water jacket drain petcock should have been? Just ahead of the starter.
Danny
