shes cold running
Old_iron_madman
01-16-2007 09:31:34
well the other day we got some snow, so I stayed up tell 1:30 in the morning to plow the driveway! I love driving my N.
Anyways I turned on the fuel and hit the starter, started up right away even tho it was around Zero degrees, I love my 6 volt! well I plowed for about an hour and drove her back in the shed and turned her off she ran like a champ, thats when I noticed that the radiator cap was still ice cold! I put my hands on the radiator hoses and they were cold as well, I then put my hand on the block and it was just "warm".
does any1 else have this problem with their 8N? I have never noticed this be4. and yes it has a thermostat, brand new I might add..
she ought to be warmer, any1 have any thoughts?
lonestarjeff
01-16-2007 16:08:40
 Re: shes cold running in reply to Old_iron_madman, 01-16-2007 09:31:34
Try cutting a piece of cardboard to fit behind the grill to block the radiator. See if she warms up. You can always cut a smaller opening in the cardboard to regulate temp.
Seems like the t-stat would stay closed if water temp stayed that low, but maybe the volume of water in the radiator(combined w/ the low temp)causes the system to cycle too quickly for the t-stat to keep up.
Jeff
Stumpalump
01-16-2007 09:41:55
It has been stated that the cooling system is overkill on this tractor. Lets say Henry designed it to run on a 110 degee day. Now you are operating it at a temp of 110 degrees colder. It wont take much zero degree air to cool it. That cold air is also cooling the exposed metal engine and thats really a lot of surface area at that temp.
Old_iron_madman
01-18-2007 09:27:22
 Re: shes cold running in reply to Stumpalump, 01-16-2007 09:41:55
thats interesting you say that, I wonder what people did back in the day...
thanks for the responce guys... I guess I will check that thermostat, but it makes me wonder if the timing has something to do with it. with my experiance in cars I have noticed some change in temp tho hardly scientific, with diffrent advance curves and timing...
Ball Bearing
01-16-2007 09:39:12
Brand new or not, change that thermostat. Lots of them out there -bad outta the box. BB
dan hill
01-16-2007 09:59:38
 Re: shes cold running in reply to Ball Bearing, 01-16-2007 09:39:12
It would have to be stuck open.Test it in a tuna can on the stove.Some water and a meat thermometer will do.Its 15 degrees here to day,Tractor wont heat up.
