I will differ from others it may be well worth the price and may be worth $950 its hard to say wif out be’n their to look it over. I spec you need to find out what to look fer far as ware and tear on a N izz concerned so you will have a better trained eye when look’in. most enny N will need $1000.00 in fix up’s to git it in tip top shape but its how soon it will be needed that’s the concern. My turn offs, cracked engine block, worn tires, rear axle hub ware, weak hydraulics, oil leaks, steer’in ware in the box and tie rods, cooling system, condition, the inside of the fuel tank, Oil pressure HOT, Tin, Has it had a loader on it look fer a non OEM front crank pulley and a oil pan wif a long crack that has been welded up (run as fast as you kin) It may be the crank pully has been replaced but if the OEM ratchet nut has been replaced wif a slotted head type bolt it had a loader on it no doubt, loaders aint to kind to a N. Guess I am look’in fer the perfect N ain’t I. Sumtimes if you git enuff good equipment wif a n you may git a free tractor, Equitment sells good. What makes me look the other way izz a nice hood and fenders but they are far and few apart but I like to run my hand across a nice hood. I also concider a N wif a original grill in great shape to be taken as one that has been looked after well. I have found only one that way but the engine wuz worn out but still gave it a home.
