Brush Hog Set Up
Sal
05-29-2001 15:35:34
3 Questions for 5' Brush Hog Set up on 8N:
1, Using the middle hole for the top link, about how long should the top link be?
2, The draft lever, under the right side of the seat which position should I set that at horizontal or vertical?
3, The rear wheel on the hog, how should that be set up? Am I looking for a certain angle for the rear tire or the overall deck?..I once heard something about setting the angle to reduce scalping, but don't remember it all.
...and thanks to Dell..." an ORC for a safer day".
Thanks
8NRay
05-29-2001 16:51:50
 Re: Brush Hog Set Up in reply to Sal, 05-29-2001 15:35:34
I set the height I'm going to cut by the rear wheel height. Then use the center link 'toggle' to set the deck level when the rear wheel is supporting the weight of the rear of the cutter. Draft lever up for position control. Then set the level control quadrant to acheive the same height in front as the rear. I then set the wing nut on the quadrant so that I go back to the same height every time I drop the cutter. On my setup I have to be carefull not to raise it too high, else the drive shaft hits the deck of the mower. It works for me.
anthony
05-30-2001 04:59:42
 Re: Re: Brush Hog Set Up in reply to 8NRay, 05-29-2001 16:51:50
i myself just bought a brush hog cutter 5` i like the help here. i am confused on one part in this explanation. if the rear wheel is to set the height, and the toggle pin is used to level the deck, why then or how does the hydraulic lift arms need to be adjusted for height? I am totally new to this so please for give the lack of knowledge, thanks this is a grerat place to find help
Dell (WA)
05-30-2001 06:09:01
 Re: Re: Re: Brush Hog Set Up in reply to anthony, 05-30-2001 04:59:42
Anthony..... ..you always use the hydraulic lift arms to set the "height" of the brushog. and you want the back of the hog to be higher than the front. OTHERWIZE the blade will cut the grass many, many, many times before you finish mowing. think about it..... Dell
Dell (WA)
05-29-2001 16:46:01
Sal..... ..
2) the position control lever should be up for brushoggin, horizontal for plowin.
1) I set the top link length so the pins slide in when I mount the hog and then I leave it. 3) Set your hogs tailwheel a little taller, so that the front of the hog is only mowing the grass once.
I use height limiter chains to set the front of the hog, its eazier on the hydraulics and when I come to an obstical, I can raise the hog and the chains collaspe. Then I can drop the hog back to the height that the chains are set without worrying about where I set the hydraulic lift control. Limiter chains, buy them $30-40, or make 'em.
I am pleased to learn that you have ORC'd..... .Dell, the self-appointed ORC safety preacher
Bill C.
05-29-2001 18:41:12
 Re: Re: Brush Hog Set Up in reply to Dell (WA), 05-29-2001 16:46:01
Dell:
Would like to try your concept of using "height limiter chains". Any help as to where to attach on 9N tractor would be greatly appreciated.
Thanks;
Bill C.
would it ? . . . Dell (WA)
05-29-2001 19:48:23
 Re: Re: Re: Brush Hog Set Up in reply to Bill C., 05-29-2001 18:41:12
would it surprize you that a fellow by the name of rossow posted a really neat drawing and instructions to do-it-yourself and you should be able to search the N-Board "archives" for the necessary information..... ..Dell
Ultradog MN
05-29-2001 19:03:55
Yeah,
If someone would post a picture of the limiter chains on a 2n I'd love to see it.
Try this.
05-30-2001 11:50:55
 Re: Re: Re: Re: Brush Hog Set Up in reply to Ultradog MN, 05-29-2001 19:03:55
This is a drawing from Rossow that Ed has saved.
The next image in his album is a drawing of how to make them
NOTE: the drawing shows using the top hole in the top link rocker - you should ALWAYS use the lowest hole. ONLY exception I can think of is, when in draft mode and using a cultivator you may wany to use the top hole for finer/quicker response to the drag of the cultivator. That will keep from digging in TOO deep and possibably ripping out the crop you are cultivating.
HTH,
Larry 8N75381
would it? . . . Dell (WA)
05-29-2001 19:50:26
would it surprize you that a fellow by the name of rossow posted a really neat drawing and instructions to do-it-yourself limiter chains and you should be able to search the N-Board "archives" for the necessary information..... ..Dell
Sal
05-29-2001 16:50:54
Just making sure I got this part right.
"Set your hogs tailwheel a little taller, so that the front of the hog is only mowing the grass once"
so the front of the hog by the 3 pt hitch is a bit lower (3"-4")than the tail/wheel right?
Thanks.
yep . . . Dell (WA)
05-29-2001 17:37:34
 Re: Re: Re: Brush Hog Set Up in reply to Sal, 05-29-2001 16:50:54
thats what seems to work bestist..... .Dell
