Oil Breather
2Nnewbe
01-20-2007 09:02:57
Does anyone have an exploded view of the oil breather? I want to take mine apart to give it a good cleaning and replace any missing or worn out parts while I am there.
Thanks,
2Nnewbe
Indiana Jones
01-20-2007 09:19:18
 Re: Oil Breather in reply to 2Nnewbe, 01-20-2007 09:02:57
Do you mean the oil bath air filter?
Stumpalump
01-20-2007 09:14:54
You said oil breather. That is the thing on the engine oil filler tube. Mine comes apart for cleaning and is filled with a brillow like mesh. I think the old ones are sealed but maybe you can soak it in gas. You may be refering to the air breather which uses oil. This site sells the best book and it has exploded views. Its called the I&T FO-4 shop manual. Thats the one you want.
Both filters are pretty simple and you can pop them open too look. The air filter uses a similar mesh. I bet sombody here will send you a picture if you hang on.
