For those of you using Neil's 12 volt wiring diagram to do your conversions, his reference to a "side marker" light means an indicator equivalent to bulb type #194, which has the right electrical characteristics to act as an idiot light and to excite the alternator. Not just any bulb will do! (the #194 is 270mA @ 14v).The problem with the "wedge plug" #194 bulb is finding a suitable socket that you can mount on the instrument panel. Good luck. A bayonet bulb with similar electrical properties is type #1891 (240mA @ 14v), and Radio Shack makes a nice barrel-style holder for it with a translucent red screw-off cap (part# 272-325); all you need is a 9/16" dia (I think) hole in your dash. I passed on the diode exciter alternative (diodes can fail). My bulb will fail also, but it's sure easy to replace it when it does. I'm using my old pulley on the alternator, so after starting I have to rev up to about 1000 rpm briefly to excite it, but then the light goes out and my voltmeter moves from 12v to 14v and off I go. Once "excited", the alternator continues to charge at all RPM's except idle; with my big pulley it just doesn't spin fast enough at 400 RPM to produce any juice. But it doesn't sit around just idling very much.
