Relief Valve
Poot
01-30-2007 12:32:20
third party image
I pulled the PTO so I could change out the relief valve & it made it alot easier. "Remove 4 bolts & slider out.. simple eh?" The valve I removed from the tractor is identical to the one in the FO-4 manual... BUT, the replacement I bought is different. Did I get the wrong one, or is this an updated version?
Mike OH
01-30-2007 14:23:38
 Re: Relief Valve in reply to Poot, 01-30-2007 12:32:20
Just curious. Did you drain the oil or were you able to park it nose down and left the oil in before removing the PTO? I was wondering myself just how difficult it would be to do like you did and not drain the oil. My oil is new, and I should have replace the relief valve when I had it apart, but didn't think to do so.
Thanks.
Mike OH
8N 515797
Poot
01-31-2007 06:43:05
 Re: Relief Valve in reply to Mike OH, 01-30-2007 14:23:38
Thanx GAJIM. Mike... you can do like Jim said, or just put a bucket under the shaft & unbolt it. About 2 1/2 gal of oil will come out, so be ready for it.
GAJIM
01-30-2007 14:50:23
Mike: I parked mine nose down in a ditch when I pulled the PTO shaft to change the relief valve. GA Jim
GAJIM
01-30-2007 13:29:06
Poot: It's an updated version. I put the same updated version in my '52 8N - cured my leakdown problem. GA Jim
