Order Ford 8N Parts Online
8n Serial Number
Ron Gil
01-31-2007 10:32:19
I have an 8n that has a small placard on the left side of the clutch housing. The number reads (NK170), and below that number reads, 8N-B. Is this the serial # for this tractor? Or is there another location that I should look? Any help would be appreciated,I am trying to get the correct serial # to purchase parts.
don b
01-31-2007 11:36:43
 Re: 8n Serial Number in reply to Ron Gil, 01-31-2007 10:32:19
Ron.....you have a 1951 model tractor,according to your casting numbers.The motor was build in Sept. 1950.Should have side mount dist. don b
souNdguy
01-31-2007 10:52:10
left side of eng block on a 1x 3" flat boss.. near the head, aft of the oil filter canister..
sn on 8n will start with 8n.. sn on 9n/2n will start with 9n..
Soundguy
Colin King
01-31-2007 10:47:45
That's a casting number you're seeing there. The official serial number is on the side of the engine block.
Take a look at John Smith's really good identification page to help you along. Once you have a serial number off the block, come back to this site and look up the number using the menu on the left side of the page, or we can help you further.
Good luck!
Colin, MN
