Update Broken lower lift pin
NorthTexas8N
02-03-2007 18:23:38
I have all back togather and everything is good,replaced lower lift pin, seal, gaskets,and breaks on right side. Thanks for all the help!!!Larry
Carl S in NH
02-03-2007 19:40:41
 Re: Update Broken lower lift pin in reply to NorthTexas8N, 02-03-2007 18:23:38
Good work there, Larry! And it seems like you did all that in a relatively short time. Now you can get back to that job you were doing when you broke the pin. Just out of curiosity, did you go in from the left side trumpet, taking out the diffy, or from the right side? Someone else suggested possibly getting at it through the PTO shaft hole. Just wondering which method you used and how easy/difficult it was.
Glad you're back in action now!
Carl
Tm N MS
02-03-2007 20:25:21
 Re: Update Broken lower lift pin in reply to Carl S in NH, 02-03-2007 19:40:41
My imagination just can't stretch far enough to see how you could possibly do it through the PTO shaft opening.Mine was aggravating enough to do with it laying out on the ground the normal way..especially dealing with the cotter pin and the super tightening that it needs..
Carl S in NH
02-03-2007 21:23:23
 Re: Update Broken lower lift pin in reply to Tm N MS, 02-03-2007 20:25:21
I just remembering reading about it in the posts under his original post about fixing it.
Link below
Carl
