Lift cover
Poot
02-04-2007 16:50:26
It seems to me that someone had a way to replace the lift cover by himself. Does anyone remember who that was / is? Thanx, poot
Rip Van Winkle
02-06-2007 04:15:52
 Re: Lift cover in reply to Poot, 02-04-2007 16:50:26
I have done mine 3 times by my self. I learned from one of my ford manuals. The manual says to stand at the back of the tractor and tilt it into place. While it is resting on its rear most edge you can hold the front edge up about 1 inch with your left hand and use your right hand to guide the lever into the pump.
I think this method is better then when a helper tries to stab the fork for you. I have the electronic manuals on cd I think it is in the training manual. I also have a bad back but I do have very strong arms. Good Luck Rip.
ZANE
02-05-2007 07:23:36
Whan I was a lot younger, a lot stronger and a lot more foolish I always did it alone by myself. I just stood on the running board is they were still on the tractor and if not I stood on the axle housings and lifted the thing off by myself. I then sort of balanced it on the back of the differential till I could get around the wheel and picked it up and put it on a vice or a table to work on it.
Went back the same way. Balance it on the differential housing Climb on the tractor while still balancing it and then grabbed it by the left lift arm and the touch control quadrant and carefully lowered it onto the tractor. I didn't even try to place the control rod into the eye of the control valve till I got it laying on the tractor. Then I got off and went to the right side and lifted the right side of the lift housing with my left shoulder while I stuck my hand down in the oil and guided the contro rod into the control valve eye socket. then I aligned the gasket and put the bolts back in and tightened them up.
Zane
souNdguy
02-05-2007 06:33:28
I did it similar to dan.. .. just grunt it off.. and then grunt it back on.
When i repalce dthe pump.. I did use a long handled screwdriver and a floor jack to get the arm and valve to line up... took a few minutes of monkeying around.. but worked fine..
Soundguy
Upper Peninsula, MI
02-04-2007 19:56:27
I just took one off and use a come-a-long above it attached to the two seat bolts with a chain. Just crank it up and slide it out of the way. Lower it down and then grunt real hard lifing it up and putting it into the back of the pickup truck. That's my way of doing it. ron
Hobo,NC
02-04-2007 18:25:51
Poot I would like to add one more thang. Fer sum reason when I werk on a lift system and have help I tell’em to start the tractor then I stand on the lift arms and werk the lift control like I am the smart one in the crowd. It did not take me long to figger out that a turning PTO will take on all comers and I like my manly voice and not look’in fer a change. Do not operate the lift from the rear of the tractor less you want to change yer 6exual preference that izz if you live thru it.
Poot
02-05-2007 05:57:39
 Re: Lift cover in reply to Hobo,NC, 02-04-2007 18:25:51
Hobo,
I learned about PTO's about 60 years ago. I always wanted to be around the tractor when it was in use, & one day I wanted to show my Uncle how much I had learned about hookin' things up. I ran right in there & WHAP! My Uncle went up side my head & said: " Stay the He## outta there boy! This thing will wadjer a$$ up!" After I got thru bawlin', he 'splained it to me. A real good, & quick lesson!
Poot, the edjicated.
Tm N MS
02-04-2007 18:01:19
I used a small electric hoist on my 2N. Never had done it before.. Nothing to it..
Poot
02-05-2007 05:23:39
 Re: Lift cover in reply to Tm N MS, 02-04-2007 18:01:19
Tm, I have a small El Cheapo electric hoist as well as a come along as mentioned by U.P. but sumtimes my brain has a tendancy to lock up on me!
nowadda mean?
Tm N MS
02-05-2007 14:57:01
 Re: Lift cover in reply to Poot, 02-05-2007 05:23:39
Yes Sir I do know whachamean. This lottle 500 lb hoist has been real handy for the cover and when I had to remove my trumpets to fix my lift arm leaking pins..Good luck..
Dunk
02-04-2007 17:08:16
I've done that about 3 times without any help with a bad back.
But I think your answer is in my Buddy, his Highest Grand Poteet, Mr. Hobo.
Try this link on fer size.
Poot
02-04-2007 17:25:15
 Re: Lift cover in reply to Dunk, 02-04-2007 17:08:16
Thanx, Dunk... Reckon ya gotta bad back from installin' 3 lift covers? Them suckers are heavy.
Dan
02-04-2007 17:06:50
I did mine by myself. Stand behind the tractor and install it that way. Also, get some 7/16" X 14 about 3" long and cut the hex head off the top. Screw two in at opposite corners to use as guides and to keep the gasket in place.
Good luck,
Dan
Poot
02-04-2007 17:32:01
 Re: Lift cover in reply to Dan, 02-04-2007 17:06:50
Thanx, Dan. I already had the headless bolts in place, but I fergot how I was sposta hold the cover UP & reach around to line up the control lever at the same time.
