How to do the string trick with a new shifter boot
Rick from Paso
02-05-2007 19:13:33
I know I read about it somewhere but didn't get the exact version for dummies! Thanks for your help. I helped a windshield installer do this with our freightliner winshield, but don't see how it would go with a shifter boot.
Rick from Paso
02-06-2007 13:07:47
 Re: How to do the string trick with a new shifter in reply to Rick from Paso, 02-05-2007 19:13:33
Did the hot water and turn it inside out trick, worked great! Thanks again for your help!
TimPa
02-06-2007 04:51:38
i have had great success just by putting a thin layer og grease on the shifter and the inside of the boot, and pulling it down. don't know if the grease attacks the rubber or not, buit i can't hurt the seal.
K.LaRue-VA
02-05-2007 19:31:35
You take a piece of string and put it behind where you want the rubber to go. In this case you just wind about four turns around the shifter. Then, you push the boot down and pull the string a little bit at a time all the way around, to work the edge of the boot where you want it to go. Just pull the rest of the string out once you get it close.
Drmeatman
02-05-2007 19:22:11
Rick, I don't remember the string trick either but I put my shifter boot in almost "HOT" water for about 5min. then sliper on. No problem.
