reddogge..... ....you write..... "They worked a lot of years ago and I've let them go"..... ...unless yer sphincterly challenged, lett'em go and buy NEW. Heres the deal, as I see it. The early dealer installed 9N litekits, all had UN-SEALED headlites, taillites, worklites. Because they were unsealed, the reflectors corroded (which was the driving force for sealed beam headlites), the buckets (shells) rusted thru, and in general are operationally unsatisfactory. (read that as DIMM) You can get later 8N style SEALED BEAM headlites that fit just fine. You can get later 8N style sealed beam worklites with toggle switch that fit just fine. You can get 8N style taillites with quality sealing gaskets that fit just fine. They all "look-like" N-Tractor accessorys. (wonder why?) Or you can get generic sealed beam tractor headlites, worklites, and taillites for cheaper at most agricultural emporiums. Bottom line, I don't know of any early 9N replacement litelenses. I know what I'd do, 8N-itt ..... ..respectfully, Dell, the non-correct
