Tall steering shaft
rbell
05-31-2001 11:11:59
Ok N guys, I see a 2N every night on the way home from work. It has the small front and rear wheel bolt patterns (like a late 2N would), it has a 3 speed transmission (yup I stopped and looked) But, it has the tallest steering shaft I have seen. The steering wheel sets at least 6 inches higher above the hood than all the other Ns I have looked at. Was there an optional length available for tall farmers?
Steven Bastardi
06-01-2001 17:33:28
 Re: Tall steering shaft in reply to rbell, 05-31-2001 11:11:59
third party image
My latest project is to restore a basket case 51 8N. This tractor had the correct steering box but the shaft was from an NAA which made it about 3" taller than normal. When I went looking for a new shaft I learned there were further differences even with 8n shafts. although they were the same overall length the worm sections are backwards and different lengths. The following picture shows differences between early 8n and NAA. The NAA will actually go in a late 8n box but the shaft will be 3" higher
Steve
MikeC
05-31-2001 14:53:52
This is just a shot in the dark-is the steering shaft from a Funk conversion longer than standard? If so, could this be cobbled together from a Funk? If not, could a tall farmer just have added some length to it? Just a thought (dangerous territory for me sometimes...).
bg
05-31-2001 20:23:25
 Re: Re: Tall steering shaft in reply to MikeC, 05-31-2001 14:53:52
Another shot in the dark: the NAA and 100-series had a taller steering column. Is it possible that one such unit has been retrofitted?
Mountainman
05-31-2001 12:36:37
It sounds like a hybred tractor. The wheel bolt pattern suggests an 8N, the trans a 2/9N, and the steering maybe from a later model. But I don't think a later model steering box fits on the 2/9N transmission so something doesn't add up.
Mountainman (CA)
