hydraulic lift lever
Razvy
02-09-2007 20:56:33
third party image
I am in the process of rebuilding my 9N and i realize after i finish painting the hydraulic lift lever that had a weld and is not strait like the original one ,you guys thing that is a modification of same sort? The hydraulic worked just fine before i started the job, any suggestions . thanks.
Razvy
02-09-2007 21:06:25
 Re: hydraulic lift lever in reply to Razvy , 02-09-2007 20:56:33
I'm trying this picture one more time .
[IMG]http://i30.photobucket.com/albums/c322/razvy/Hydraulic.jpg[/IMG]
Empennage
02-09-2007 21:19:09
 Re: hydraulic lift lever in reply to Razvy , 02-09-2007 21:06:25
Razvy...I am going to go out on a limb here but I think someone was a little scared to take the Hydraulic cover off and put in a new pin.
Razvy
02-09-2007 21:27:54
 Re: hydraulic lift lever in reply to Empennage, 02-09-2007 21:19:09
Empennage...which pin you referring ? looks like somebody cut it in a angle and weld a new position . Why ?????
Empennage
02-09-2007 21:33:28
 Re: hydraulic lift lever in reply to Razvy , 02-09-2007 21:27:54
The Cam Follower pin. Otherwise I have no Idea why someone would cut and weld the lever like that.
don t-9n180179
02-10-2007 01:39:29
 Re: hydraulic lift lever in reply to Empennage, 02-09-2007 21:33:28
If he truely has a 9N, there is no cam follower pin. 8N's were the only ones that had em. My lever went bent to get around FEL pipe, but mine was bent on the flat. Can't help otherwise. Have fun, play safe.....don t. .....
Razvy
02-09-2007 21:46:08
Tomorrow project ...lol
Empennage
02-09-2007 21:49:17
 Re: hydraulic lift lever in reply to Razvy , 02-09-2007 21:46:08
I hear you. Always make the time...tomorrow. lol.
