Crank pully
rasputen.......
05-31-2001 19:13:07
I am about to finally replace the wobbly crankshaft pully.I did a search and got lot's of info,(rope trick,not too high grade bolt,1 5/16").
I still wonder if I can still use my hand crank bolt on the new pully from Don B, or if I can do some mod on the new pully to keep the crank bolt?
Also, is the bolt right hand thread? I suspect so since I saw no mention of lefty tighty-righty loosie.
Steven Bastardi
06-01-2001 17:16:39
 Re: Crank pully in reply to rasputen..........replacing crank pully, 05-31-2001 19:13:07
I'm using a new billet replacement pulley from Don B. and an original crank bolt without any problems.
Steve
Dell (WA)
05-31-2001 23:00:15
the OEM crankshaft pulley bolt has a tapered backside to center the OEM sheetmetal pulley on the nose of the crankshaft. My billet replacement pulley (designed for frontmount hydraulic pump) did not have a relief for the taper so I used a regular bolt (5/8 - 18 X 1") and a flat washer. Doesn't wobble anymore..... ..Dell
