Top Link hitch pin size
Paul Schultz
02-10-2007 07:17:46
My 53 Jubilee tractor is away from our house (down the road at our land). I want to buy a new top link hitch pin today. What diameter does the top link take? I want to avoid the trip to our land with a tape measure.
Thanks,
Paul.
Paul Schultz
02-10-2007 14:14:26
 Re: Top Link hitch pin size in reply to Paul Schultz, 02-10-2007 07:17:46
Thanks everyone.
Paul.
murn ga
02-10-2007 08:12:33
Top link pin is 3/4" the lower hitch pin is 7/8".
Hobo,NC
02-10-2007 07:44:13
7/8"
craignaa
02-10-2007 07:36:10
Standard Cat. 1 link pin.....
Paul Schultz
02-10-2007 07:37:46
 Re: Top Link hitch pin size in reply to craignaa, 02-10-2007 07:36:10
I'm heading to a non-tractor supply store and thought I could make due with a trailer type hitch pin. So I wanted to get the diameter. Should I avoid this type of hitch pin?
Paul.
Dell (WA)
02-10-2007 09:59:41
 Re: Top Link hitch pin size in reply to Paul Schultz, 02-10-2007 07:37:46
Paul..... ..the top-link pin under yer butt-bucket is 3/4". Ball-hitch 2"sq receiver hitch under yer pickup bumper is 5/8" pin. The 11-hole tractor drawbar are 7/8" holes, as are the roundball lower lift arms.
As an emergency, ennythang that fits including 3/4-BOLTS; but the preferred cat-1 3/4" upperlink pin is less than $2 (cheap)..... ...Dell
Wisconsin Cowman
02-10-2007 08:10:56
It will work just fine.
Patrick Thomas
02-14-2007 14:12:13
 Re: Top Link hitch pin size in reply to Wisconsin Cowman, 02-10-2007 08:10:56
They are 3/4" if you must you can use a bolt don't go undersize as it will cause excessive wear in the holes.
If you have a Tractor Supply or some other type farm supplier in your area you can get them cheap.
