2N Engine
Backfire
02-11-2007 11:17:56
Have a severely cracked 2N block. Anyone know where I could locate a new engine or block?? I've been looking into this for a month and am coming up with all dead ends. Do not want to abandon project if possible.
maplehillfrm,pat
02-11-2007 20:28:53
 Re: 2N Engine in reply to Backfire, 02-11-2007 11:17:56
I probably have one , when would you need it by, ? it would be a front mount dist correct? I have a good complete engine but it is still attached to the tractor,I am located upstate ny north of binghamton,
Backfire
02-12-2007 14:11:32
 Re: 2N Engine in reply to maplehillfrm,pat, 02-11-2007 20:28:53
I would like to get it as soon as possible but no real rush, its for personal use. Yes, it is a front mounted distributor. What town are you in?? You mentioned upstate, I may be able to pick it up. If you don't have a block, you mentioned that you had one on a tractor, with some help I could pull it out myself with the use of some lifting device or a set of good hands.
Drmeatman
02-11-2007 13:17:00
I don't think this site has blocks, engines but sometimes they are on E-bay. I just bought one from John Smith at 8nford.com. He has nice parts and will "treat" you OK.I hope it was OK to tell this here.
Backfire
02-11-2007 13:25:33
 Re: 2N Engine in reply to Drmeatman, 02-11-2007 13:17:00
Unfortunately, I have already talked with smiths tractors and they have none either.
Backfire
02-11-2007 11:53:13
I am located in northern NJ.
ron,ar
02-11-2007 11:50:48
what part of the country are you in?
Backfire
02-11-2007 11:54:27
 Re: 2N Engine in reply to ron,ar, 02-11-2007 11:50:48
northern nj.
