Order Ford 9N Parts Online
My 9N
Razvy
02-12-2007 21:41:12
I got this tractor on 20 Dec 06 and start working on it for tree weeks ...and hear is where I am. >>>>>>>>>>
Ramon
02-13-2007 09:58:34
 Re: My 9N in reply to Razvy , 02-12-2007 21:41:12
OK, I will be the critic! On the one pic of the starter it looks like you may have got some of the primer on the starter commutator. If so, you should polish it off before using. Other than that, it looks great. Keep up the good work.
Razvy
02-13-2007 10:03:38
 Re: My 9N in reply to Ramon, 02-13-2007 09:58:34
@Ramon Nice pick ...lool It's done . I actually clean/ prime first the unit and after i took it apart to clean grease and check the brushes. Thanks
Indiana Jones
02-13-2007 08:11:37
Looks like you are making a lot of progress. I've had mine since last October and haven't gotten as much done as you have since December.
I am taking all the paint off my hydraulic lift quadrant and after polishing with xfine steel wool, will clearcoat it.
I noticed also that yours has a drawbar with anchor underneath. Did you drill and tap the housing for this or was it this way when you got it? My 9N has a drawbar bracket by the PTO, but it is not tapped for a belly anchor (for pin). As far as I know, none of the 9Ns had these.
Looking good! Thanks for sharing the pictures.
Razvy
02-13-2007 08:21:19
 Re: My 9N in reply to Indiana Jones, 02-13-2007 08:11:37
@ Indiana Jones The draw bar was on the tractor when I got it , what the guy dead , he remove 3 studs from the bottom of the trumpet and he used 2 " bolts , the piece is made of a 2 4" angle iron . it is very nicely done , I think I have more pictures of that part if you are interested .
Indiana Jones
02-13-2007 08:37:04
 Re: My 9N in reply to Razvy , 02-13-2007 08:21:19
Razvy, I went back and took a closer look at the pics. I see how he did it. Looks strong enough for pulling a wagon or something else on wheels.
Thanks.
crazy8
02-13-2007 07:39:38
I remember seeing that on ebay. Pennsylvania?
Drmeatman
02-13-2007 06:27:44
Razvy, very impressive.It's swell to see so many hooked on preserving these N tractors.I wonder if Mr. Ford thought these Ns would be so addictive.A couple of questions please,,what type of shop is this, and I notice your "dust", what precautios do you take for your lungs? I'm not being critical because I have the same issue.It's great to get "how to" pointers.Hope to see more pics as you progress !!!
Sean (TX)
02-13-2007 03:17:51
Looks good. My 41 9N is red belly and gray tin.
third party image
Sean (TX)
'41 9N79052
kidd65
02-12-2007 22:37:33
Very nice job on the restoration. Keep the photos coming.
Razvy
02-12-2007 21:43:59
Start from the bottom ...llooll Sorry the images are not in the best order, but i am sure that you guys get it right .
Bob in AZ
02-12-2007 22:14:32
 Re: My 9N in reply to Razvy , 02-12-2007 21:43:59
Very,very nice job Razvy !!! Thats going to be one sweet machine when you're finished with it .
Bob
02-12-2007 22:05:35
Looking GOOD!
Razvy
02-13-2007 06:05:22
 Re: My 9N in reply to Bob, 02-12-2007 22:05:35
Nice Sean I love it ,beautiful . Thanks to all for the nice words , I am waiting the critics as weal ., Thanks.
Sean (TX)
02-13-2007 10:56:53
 Re: My 9N in reply to Razvy , 02-13-2007 06:05:22
Its your tractor. Paint it what ever color you want...Who cares what anyone else thinks of your paint job...
Razvy
02-13-2007 06:43:26
@ Drmeatman It's one car garage, very small to work but i manage . Regarding the dust ..? That's a problem, if you see I am not painting the entire tractor at one time, usually after i worm the garage up I shot down the kerosene heater and and I spray a coat of paint after that I leave the place, return in 2-3 hr to work in a different area. That paint dust it's in every little crack ::)))that's a different job to clean the place up .
Razvy
02-13-2007 07:42:37
 Re: My 9N in reply to Razvy , 02-13-2007 06:43:26
crazy8 Yes on the Ebay it was $1850 around Dec 15 06'
