2N Intake Stack Cover
Patrick Thomas
02-14-2007 14:44:53
Anybody have a good homemade alternitive to the original?
TIMW(PA)
02-15-2007 07:07:56
 Like This? in reply to Patrick Thomas, 02-14-2007 14:44:53
third party image
Here is the one off of mine.
Sean (TX)
02-14-2007 15:46:06
 Re: 2N Intake Stack Cover in reply to Patrick Thomas, 02-14-2007 14:44:53
Pipe through the hood?
One on ebay.
third party image
Dan 2N
02-14-2007 18:23:33
 Re: 2N Intake Stack Cover in reply to Sean (TX), 02-14-2007 15:46:06
This air cleaner as shown has some parts missing, top band and top cover.
Dan 2N
Drmeatman
02-14-2007 15:37:39
  The fog lifted !! in reply to Patrick Thomas, 02-14-2007 14:44:53
Pat I'm sorry! I had a senior moment I think. I believe your talking about the "air cleaner" pipe that extends through / and above the hood.If so they can be found.
Drmeatman
02-14-2007 15:17:14
Pat,are you asking about the exhust stack that goes up the side of the hood,cover?
Patrick Thomas
02-14-2007 15:21:37
 Re: 2N Intake Stack Cover in reply to Drmeatman, 02-14-2007 15:17:14
No, I have a pipe the extends above the hood.
GB in MT.
02-14-2007 15:38:18
 Re: 2N Intake Stack Cover in reply to Patrick Thomas, 02-14-2007 15:21:37
The air breather you discribe, (tube through the hood), was an optional thing from the factory. This let cleaner air into the carb for farmers that were complaining about the dirt/dust from their fields getting under the hood and into the carb. I also have this air intake on my 44 2N.
If I read you right, what you need is the cap that fits on the "through the hood" pipe??? Is this correct?? If so you will probably have to search for a used one, as I have not seen this for sale new. GB
Drmeatman
02-14-2007 15:32:03
Pat, let me ask it a different way,,Does this pipe/stack come from youe exhaust then up to above your hood? And is it open to catch rain and you need a cover?
Patrick Thomas
02-14-2007 15:50:17
 Re: 2N Intake Stack Cover in reply to Drmeatman, 02-14-2007 15:32:03
Its for the air intake its a bowl shaped thing that keeps out the reai
Ross Pugh(NC)
02-14-2007 14:48:51
Never saw or heard of one, original or homemade. What is an "INTAKE STACK COVER"?
Leroy
02-14-2007 15:37:03
 Re: 2N Intake Stack Cover in reply to Ross Pugh(NC), 02-14-2007 14:48:51
On 9N & 2N the orignal factory air intake to the air cleaner is under the on the right side of the battery where they collected all the dirt. There was a different top made for to fit the air cleaner with a pipe that you cut a about a 2" hole in the hood for it to go up thru and was about 10" above hood with a metal cover with screen bottom on top. That saved a lot of engines from dirt when the tractors were regulary used in working ground in the fields as the Ford being the big or possibly only tractor on up to 160 acre farms. I fave never tried it but the intake stack cover for an H Farmall is very close in size and also of the same type. The top off a 5000 Ford oil bath air cleaner may also be able to be made to work.
Ross Pugh(NC)
02-15-2007 06:55:56
 Re: 2N Intake Stack Cover in reply to Leroy, 02-14-2007 15:37:03
Ok, now I understand what he is talkin 'bout.
