Ammeter
Razvy
02-17-2007 13:07:24
Ammeter ??? How is this gage work , I have a wire thru a loop behind the ammeter, If I change the gage / length it's going to effect the gage ?
Dell (WA)
02-17-2007 13:49:59
 Re: Ammeter in reply to Razvy , 02-17-2007 13:07:24
Razzie..... ..they NO LONGER make the "inductive-loop" ampmeter. All replacement ampmeters are 2-terminal ampmeters and need the ampmeter wire cut and spliced so the charging current goes THRU the 2-terminal ampmeter.
Just for your edification; the OEM "inductive-loop" ampmeter is only a 20% accurate meter. The 2-terminal ampmeter is just 10% accurate. Even the cheapest hardware voltmeter is 5% accurate. My professional grade digital meter is 0.1% accurate.
And don't worry, ampmeter don't care 6-or-12 volts, works the same. Center reading ampmeter don't care positive or negative ground, but you care. You're trained to interpert positive ampmeter reading as charging the battery.
Bottom line, don't get hung-up on tractor indicator meter accuracy. Iff'n it wiggles, its accurate enuff..... ..Dell
soundguy
02-17-2007 13:23:01
Length of the wire won't effect it.. It's magnetic field based, It's an inductive meter. I wouldn't go smaller than the oem gauge, since charge current goes thru that line.. and Max size is limited by the loop size... etc.
Soundguy
Razvy
02-17-2007 22:48:35
 Re: Ammeter in reply to soundguy, 02-17-2007 13:23:01
I understand now , simple ... looll when you got the answer , Thanks 2 u
