Steering gear alignment
Razvy
02-17-2007 22:44:39
I am ready to reinstall the stering upper housing and the gears but I am having difficulties understand the manual , it;s a simple way of doing the alignment ? , you guys now any tricks ? My other question ..: It's a god idea to grease the bearing race, sector shaft, pinion and sectors whit bearing grease prior to installation ? or use oil ?
VTXscooter
02-19-2007 21:18:04
 Re: Steering gear alignment in reply to Razvy , 02-17-2007 22:44:39
third party image
Here is a picture to help visualize the alignment during assembly. I have a 1942 9N, and I am rebuilding allot of mechanic"s on it.
I put assembly lube on my bearings. The 9N/2n are splash lubed so it doesn"t hurt to start with some lubrication on a dry bearing.
Let me know if you need any more pictures.
Joe T
Razvy
02-20-2007 06:03:10
 Re: Steering gear alignment in reply to VTXscooter, 02-19-2007 21:18:04
Thanks Joe I understand know how it works, you doing a nice job , I got the oil line broke on mine in the same spot ..lool
RP-40-9n
02-18-2007 09:03:21
you didnt say if its 8n or 9n. im thinking from your earlier posts that you have a 9n, but not sure. RP
Razvy
02-18-2007 18:30:53
 Re: Steering gear alignment in reply to RP-40-9n, 02-18-2007 09:03:21
It's a 9N
soundguy
02-17-2007 23:02:00
No need to pre grease.. you will be filling the box with lube after reassembly.
I found the fo-4 manual VERY clear on how to time the gears. In fact.. i can't think of anything to add or clarify as to what the manual states for timing the sectors and worm/ballnut.
All you are doing is locating the gear witht he master spline, and then counting teeth on each one and meshing them at the proper teeth.
Along with that, have the ballnut centered ont he range of motion of the worm, and have than in place when you time the sectors.. and you should be good to go.. same number of turns lock to lock.
Soundguy
Razvy
02-18-2007 05:07:48
 Re: Steering gear alignment in reply to soundguy, 02-17-2007 23:02:00
Soundguy I know the manual , the manual doesn't know me . I am have big problems whit English I come to US without knowing 2 words. So let me take this opportunity and apologise to all if i make same mistakes wants in a wile , I am very lucky whit the spell check on my computer if not I well be to embraced to right. Thank you for understanding .
soundguy
02-18-2007 17:23:42
 Re: Steering gear alignment in reply to Razvy , 02-18-2007 05:07:48
Forget the words, follow the pictures then.
Soundguy
