Order Ford 9N Parts Online
9n/2n rear axle hot rivets
Ron K '46 2n
02-03-2000 09:00:22
Ran into an interesting problem and wondered if anyone else had encountered it. On one of the rear wheels, the hot rivets that hold the hub to the axle loosened up. There's about 1/8th inch of movement on the rivets. I already found another used one, and have replaced it. The guy I got the used one from said he had never seen that happen. I was wondering if anyone else has had this happen, what are the possible causes,and if there is a way to repair my old one, or is it hopeless?
Thanks for any info which can shed some light on this.
AL@NC
02-03-2000 10:04:48
 Re: 9n/2n rear axle hot rivets in reply to Ron K '46 2n, 02-03-2000 09:00:22
Thats fairly common. I had two loose ones on my 9N which I welded. That is the reason ford switched over to the one piece unit.
llamas
02-03-2000 12:14:50
 Re: Re: 9n/2n rear axle hot rivets in reply to AL@NC, 02-03-2000 10:04:48
No, actually, it was the other way about. The hub/axle assembly was originally a one-piece unit, later modified to the rivetted assembly.
Finding someone to wallop hot rivets these days is not easy, and the whole thing has to be torn apart to back up the new rivet. When I found this problem on mine, I burned off all the rivets and replaced them with 1/2" grade 8 bolts and lock nuts. If the you get the length right there's exactly enough room to slip the bolt through from the inside.
I've since done this same repair on others and had no problem whatever. You could weld the loose rivet to the hub on the outside, I guess, but it'll still be loose on the inside unless you tear it all apart and weld the inside as well.
llater,
llamas
Mason W.V.
02-04-2000 16:09:27
 Re: Re: Re: 9n/2n rear axle hot rivets in reply to llamas, 02-03-2000 12:14:50
Reriviting is not hard at all! Im an Ironworker thats one of the enjoyable parts of my job. I do not know how far you have to ship but the price is not that bad.If anyone would like this done E-Mail me @ mason_wv@myself.com If you need original look need old rivit.
