This is on an early 8n with a 12 volt conversion using a cylinder/automotive type coil. The tractor would start and idle but die if I let the clutch out while in gear. A friend at work suggested I check the points. I've never messed with points before. I bought one of the points/condenser/rotor kits and a new cap from Farm & Home. This is where project creep sets in. First, the old cap was shot, the contacts were worn down and there was a crack where the top of the rotor contacts the cap. The problems started when I removed the coil wire from the cap. The cap end of the coil wire has a connector that looks the same as the spark plug wires on the cap end, a small copper tube with a split down one side crimped onto the wire. I can't figure out how this connects to the new cap. The previous owner had it laying on top of the contact at the top outside of the cap. There was no boot and all that held it in place was half a pound of silicone caulk. What kind of connector is supposed to be there? I can't figure out how anything would attach. The only things I've done so far is removed the old cap, labeled the plug wires and marked where the rotor was pointing. I want to get this figured out before I remove the dist. to mess with the points or I'll confuse myself for sure. BTW, how much play is acceptable in the rotor? Mine seems awful loose. Sorry this is so long, but I figure more info is better than not enough. Thanks for any help.
