Order Ford 9N Parts Online
front wheel bearing 9n
prairie boy
02-19-2007 19:59:04
have a 9n with front wheel hub that does not fit properly into position on the spindle. the hub is sitting about 1/4" further away from spindle than other side. the inner bearing race is sitting properly in position in the hub. can any one help with this problem? thanks
Dell (WA)
02-19-2007 21:39:46
 Re: front wheel bearing 9n in reply to prairie boy, 02-19-2007 19:59:04
PrairieBoy..... ..check yer spindle seal. Rubber/leather part facing OUT..... ..Dell
Ntoxicated
02-19-2007 20:39:12
Its not much help , but switch your left and right hubs and see if the problem switches sides or not . That will atleast tell you if the problem is in the hub or the spindel.
