hyd lift
ohio gene
02-20-2007 07:06:34
my hyds on 8n would not work with draft control lever in up position would work with lever in down position found cam an cam follower pin wore half way down after replacing cam an pin an checking all adjustments lift works with draft lever in up position but no lift with lever in down position need help
thank you
