Ok, my apologies. I should know this, and I loooked into past entries and still need some direction.The trouble, I have no power under load. Using a brush hog or finish mower, if the grass gets just a little tall (hog) or thick (finish mower), the old 8N will bog down or just flat die, even in 1st gear at near full throttle. I have also noticed the tractor seems to be getting hot. There is no thermostat installed and the fluid level is just over the core fins in the radiator. After running under a slight load for a while, even on a cool day (60s), when I shut down I can hear the coolant bubbling/boiling in the engine.... 50/50 mix of antifreeze/water. I have run with the cap off and can see the cooIant ciculating quit well. I am also getting a "pinging" or "knocking" under load. On the other hand, the tractor always starts easily and idles fine... it does seem to take a while to warm up... several minutes before I can take off without the engine sputtering or dying (no thermostat?). Once warm... 3 - 4 minutes, no trouble. Here is what I have cheked thus far..... Fuel supply - good fuel flow and I have made sure the screens in the carb elbow are clean - not obstructed. Compression - ran for a few minutes and checked with all cylinders dry 120-120-90-90. Maybe a weepy head gasket? I have found no eveidence of water in the oil, or oil in the cooling system. I have done Dells governer check,,,grabbed the carb link and accelerated and the governer pulled back pretty hard. I have not changed points yet (front mount distrib.). Good next step? Anyway, suggestions appreciated. I have been using the tractor this winter to pull a small trailer for hauling wood around, and not really putting a load on. Runs just great using for that. Went to hog some dead grass before it started growing again and the power loss seems to be much worse than last fall. Thanks in advance. Odie1
