44 2N originality ?
44'N_Keith
02-22-2007 10:47:08
I posted earlier that I am collecting parts to start a restoration of a 44' 2N. One of the responses to that post was "did I need a magneto" My question is this, should this year tractor have only a magneto to be correct, because my tractor has full 6V electrics including lights, which all look original to the tractor. It is definately a 2N, 3 spd trans, tubular radis rods, Freguson sys. badge on the grill, push button starter in the tranny cover, spring bails on the air cleaner. Do you think I have a later 2N with a 44' block? What are some of the casting codes or other clues I can look for to truly know the year of the tractor? BTW I don't know the engine serial number right off, but when I looked it up before it indicated it was a 44' 2N
Dell (WA)
02-22-2007 18:14:24
 Re: 44 2N originality ? in reply to 44'N_Keith, 02-22-2007 10:47:08
Keith..... ..as best guess, ONLY the earlist 1942 2N's had magnetios instead of common squarecan frontmount distributor. Records are un-clear. The magneto'd 2N also had "arm-strong" starters (crank) and LUG'D STEEL wheels (rubber being used for tank-tracks) and NO BATTERY, (lead being used for bullets) NO STARTER, NO GENERATOR (copper being used for bullet shells)
Almost ALL EARLY 2N's were retro-fitted to rubber ag-bar tires, battery for starting motors, gennys for charging batterys. Surprizingly enuff, magnetos are relative trouble-proof. There just weren't many made due to WW2 SHORTAGES.
Do your research; Peterson & Beemer "Originality Guide" is good place to start..... . respectfully, Dell, who doesn't care about originality
1chano
02-22-2007 16:28:33
44N Keith
I don't think lights are considered original, I believe they were optional. There is a picture that shows N tractors coming off the assembly line with no lights.
GB in MT.
02-22-2007 12:20:48
Look on the lft. side of the tractor, directly to the rear of the starter you will find a casting #. That # will look something like this. E104. Find that # and post it back here, or send me an Email, and I'll be able to tell you the month, day, and year of your tractor. Also I will need the ser# off the engine.
Email is open. And no you do not need a magneto to make the 2n original. The mag. was only on war-time mod's. GB
don b
02-22-2007 11:29:51
Keith....I think you are ok.Tractors with mags had the choke rod run out thru the grille to the front of the tractor because it had to cranked with a hand crank.Also they had steel wheels.Most were retro fitted with original electrical system.Go for it. don b
Indiana Jones
02-22-2007 11:21:34
Here's some good ID info:
