Thanx SouNder...
Poot
02-22-2007 12:03:02
that's what I want it for... to keep the mower in place while I mow some pretty rough places in the pasture. The bracket appears to be stamped because all the edges are sharp. I can't get ANYTHING at my TSC. They only have (3) 6' shelves of tractor stuff. The rest of the store is mainly clothing, lawn mowers, & livestock feed. The manager had no idea what a check chain clevis was! He just said: "if we have it, it will be over there" & walked away! Amazing.
soundguy
02-22-2007 21:05:42
 Re: Thanx SouNder... in reply to Poot, 02-22-2007 12:03:02
Just to be clear.. a check chain clevis would just be a chain clevis.. and they should be over by their bulk chain.. 5/16 should work fine to hold the chain to the tabs by the pto, if that's what you are refering to.
This chain bracket, however is a depth or limiter' chain.. etc.
Some use brackets on either side of the toplink, some use a single bracket.. i seen em both ways. I made one using 2 brackets.. another list member made one using 1 bracket that bolts on somewhere near the back of his seat spring, and then attaches rearward.. etc..
Soundguy
keennt
02-23-2007 06:12:11
 Re: Thanx SouNder... in reply to Poot, 02-23-2007 03:42:14
I am going to get a mower for my 8N, I heard about using stabilizer bars to prevent sideways movement, do these 'check chains' do the same thing.???..it looks like they do.....
soundguy
02-23-2007 12:18:26
 Re: Thanx SouNder... in reply to keennt, 02-23-2007 06:12:11
yes and no. The check chains will keep the arms outta the tires.. but it will still let them swing a bit. The sway bars lock the mower in place in line with the tractor.. tha's really the best..
Soundguy
