hyd lift cover
46Lash
02-24-2007 10:15:31
Hello, I have had my 52 8N lift cover totally apart for a year. Now that I'm reassembling it I find that after installing the new bushings for the main shaft the center piece that pushes on the dogbone / piston is offset to the side. The bushings are pressed flush to the outside of the cover. Looking at how the othe linkage is going to lay in there I believe I'm OK but wanted to double check.Thanks in advance for your help.
Greg
Hobo,NC
02-24-2007 18:10:05
 Re: hyd lift cover in reply to 46Lash, 02-24-2007 10:15:31
The bone will be off to one side slitly 'bout 1/2", sounds like yer good to go, BTW it only will fit one way so you kin not be wrong.
Third Party Image
