Front axle pin
Razvy
02-26-2007 22:36:27
Guys, I want to replace my front axle pin on my 41 9N and i found on the parts list the Part No: 2N3126D ,but it's not the same as mine, they have a wrong picture / drawing ?
wwildhorse2k1
02-27-2007 00:49:42
 Re: Front axle pin in reply to Razvy , 02-26-2007 22:36:27
Hi ---- It looks like there was a change in design during the 9n - 2N. The 3126-A shows a one piece , cylindrical pin with central hole and grooves for the crank cross pin. The later ones are 2 piece and has a bolt to anchor it to the front of the support hope this helps ---
Razvy
02-27-2007 17:20:37
 Re: Front axle pin in reply to wwildhorse2k1, 02-27-2007 00:49:42
wwildhorse2k1 , not even Ford has this in the part book . Thanks for the info .
Razvy
02-27-2007 17:18:28
Thanks Dan That is the correct pin , you made my day . part no 9N 3126-A @ $40.00
VTXscooter
02-27-2007 17:45:29
 Re: Front axle pin in reply to Razvy , 02-27-2007 17:18:28
third party image
Mine has the same pin. I think this style of axle mount was changed on the 42 2N model.
My 42 9N has this mount and the doglegs mount to it. There are no holes in the dog legs.
The pin is made so a loader pump shaft will go through it.
Joe
Razvy
02-27-2007 17:59:55
 Re: Front axle pin in reply to VTXscooter, 02-27-2007 17:45:29
I have the same style Joe
