Fixing a stabilzer bar
Sal
06-02-2001 20:21:38
Got a stabalizer bar that is bent bad, is the best way to get it straight again to heat it and hammer it back to shape...or is hammering it without heat ok?
I got a replacement at Fam & Family for $10, but it's not a heavy or as good a quality. Plus I belive the bent one came with the tractor.
Thanks.
Dave iN Alberta
06-02-2001 20:46:37
 Re: Fixing a stabilzer bar in reply to Sal, 06-02-2001 20:21:38
I think that the bars are not heat treated therefore heating should not hurt anything. Just measured mine that I just got at 2-3/4" by 3/16" thick. You paid ten bucks? I think I got taken! Also is it best to have two or does it matter that much?
Jack
06-03-2001 08:22:28
 Re: Re: Fixing a stabilzer bar in reply to Dave iN Alberta, 06-02-2001 20:46:37
Two bars are best. You can's bend one by pulling on it - with 2 one always takes the pull side. With only one it has to take a pushing affect one direction which will bend it if enough force is exerted on it.
Sal
06-02-2001 23:26:56
I have always used two, seems like it would naturally give better control...but I have heard that if one is used it is common to put it on the adjustable arm side.
8NRay
06-02-2001 21:22:32
I would say 2 is better than 1. One will only stablize one side of the implement.
