Order Ford 9N Parts Online
ford 9n ticking in motor
ratt66552
03-01-2007 05:52:45
i have a ticking sound comming from the front of motor it sounds like it is comming from where the throttle links the gov it is the round unit with the iol line comming out of it i have rebuilt the oil pump,checked the valves were ok oil psi at40 could that unit have somthing loose? please help tanks
ZANE
03-01-2007 08:40:11
 Re: ford 9n ticking in motor in reply to ratt66552, 03-01-2007 05:52:45
Could be the timing gear on the camshaft. I would just leave it alone. If it comes loose all it will do is stop running. It won't damage anything in the engine such as the valves etc as some of the later engines will do when the cam stops turning. That's another thing that is good about the N engine.
Zane
ZANE
03-01-2007 08:37:42
Do you know where your pocket watch is?????
An old guy went to the doctor, "Doc I can't hear a thing out of my right eat!" Looking in the ear he told the old man, "no wonder you've got a suppository in your ear!
"Now I know where my hearing aid is!" Zane
Ross Pugh(NC)
03-01-2007 06:18:13
In the absence of a stethescope the best way to locate or isolate a noise is with a long screwdriverplaced on the engine at the location ye think the noise is coming fromand put ye ear on the screwdriver handle. Listen and move the screwdriver around until ye can hear the noise the loudest and this should be the approximate location of ye problem. A stethescope (less than $10.00 at Harbor Freight) is a cheap investment for diagnosis such as this. Amazing what ye can hear.
LeeMo
03-01-2007 10:43:23
 Re: ford 9n ticking in motor in reply to Ross Pugh(NC), 03-01-2007 06:18:13
Yep, a piece of garden hose works pretty good too.
dave guest
03-01-2007 16:26:33
 Re: ford 9n ticking in motor in reply to LeeMo, 03-01-2007 10:43:23
You passed your hearing test. I can't hear a tick, or see a tick, but if they bite I will jump.
