Order Ford 8N Parts Online
Snow Plowing with the 8N--4 of wet and heavy
8N'r--WI
03-01-2007 08:44:16
Thought you guys might be interested---
Starting out at top of the drive...
third party image
Pushing it out the end...
third party image
And across the road...
third party image
Backing up for another run...
third party image
Resting the N while moving cars,finishing up, and heading to the neighbors...
third party image
Old_School_Nut
03-02-2007 07:52:54
 Re: Snow Plowing with the 8N--4 of wet and heavy in reply to 8N'r--WI, 03-01-2007 08:44:16
yup! here comes the snow! i am located just west of janesville WI (south of madison) and the snow is blowing realy good! looks like I will have some fun with the 8n when I get home.
wayne11
03-01-2007 19:17:54
third party image
Is it a "Dearborn" like mine?
8N'r--WI
03-01-2007 19:20:29
 Re: Snow Plowing with the 8N--4 of wet and heavy in reply to wayne11, 03-01-2007 19:17:54
Wayne---same as what you have. Dearborn Model 19-3 with Universal Frame---Tim
D.B. in Mi.
03-01-2007 18:30:53
What kind of plow is that and where could I find more info on it. Looks like it sure beats a backblade., Dennis
8N'r---WI
03-01-2007 19:22:23
 Re: Snow Plowing with the 8N--4 of wet and heavy in reply to D.B. in Mi., 03-01-2007 18:30:53
Dearborn Model 19-3 with Universal Frame and Dozer Blade--See Waynes picture above--check your email--Tim
Scotts 9N
03-01-2007 17:59:18
I would really like more info on the plow, including the lift mechanism if anybody can help.
8N'r--WI
03-01-2007 19:24:57
 Re: Snow Plowing with the 8N--4 of wet and heavy in reply to Scotts 9N, 03-01-2007 17:59:18
It is a Dearborn Model 19-3 with Universal Frame and Dozer Blade. They made a Snow Blade (slightly larger than the dozer blade) that attaches to the frame. The dozer blade works great in snow.---Tim
DennyF
03-01-2007 15:12:30
Almost looks like fun.
A cousin has 3 front-mount plows, wants to sell me one for my Jubie. Think they're Sauders(?). He's got one on the front of his 861 now, but I've only seen pictures thus far.
Upper Peninsula,MI
03-01-2007 11:21:55
8N'R. I have the same plow on a 1940 N and like you it works great. I use a good set of chains and add weight to the back on the 3Pt. lift. I used a 16 gal. barrel, filled it up with concrete. The whole thing adds 310 pounds of weight. If I can find a picture of it, I will send it. If you want, drop me an email and when I find a picture will send you a copy. By the way, where are you in WI. Ron
8N'r--WI
03-01-2007 12:44:41
 Re: Snow Plowing with the 8N--4 of wet and heavy in reply to Upper Peninsula,MI, 03-01-2007 11:21:55
Ron---does your plow have any markings on it? These pictures were taken in SE Wisconsin, about 25 miles West of Lake Michigan.---Tim
8N'r--WI
03-01-2007 12:42:47
NTP
03-01-2007 13:48:14
 Re: Snow Plowing with the 8N--4 of wet and heavy in reply to 8N'r--WI, 03-01-2007 12:42:47
Where are you located in SE Wisconsin? I am located between Wales and Genesee. I have a NAA that I remove the bucket from and have adapted a Western plow to it. I can make 10 ft piles of snow.
Colin King
03-01-2007 08:53:39
Tim, Great to see that new blade in action! Thanks for the photos.
We're supposed to be getting 1-2" an hour until around 7PM tonight. I suppose that'll make it your way soon.
Colin
8N'r--WI
03-01-2007 09:56:47
 Re: Snow Plowing with the 8N--4 of wet and heavy in reply to Colin King, 03-01-2007 08:53:39
We are supposed to get some more this afternoon. The plow works great in 4", but had trouble with the 10" we had last weekend. No chains, and no fluid in the tires does not help. I had to take smaller passes in order to make it work out ok.
Tim
Colin King
03-01-2007 12:26:09
 Re: Snow Plowing with the 8N--4 of wet and heavy in reply to 8N'r--WI, 03-01-2007 09:56:47
If your 10" of snow was anything like what fell here, it was really heavy. Sounds to me like it works admirably!
Colin
