Dont know which plug
RDAllison
03-02-2007 16:00:27
Hello,
I have a Ford 8n and I dont know which plug is the engine oil drain (I orderd the manual, its on the way).I was going to change the oil. I thought that it would be an easy job, but when I looked there appeared to be four drains. One under the the engine, one under the gear shift, one under the seat and one under the back axel.
Thanks. RDAllison
StahlMaster
03-02-2007 16:05:45
 Re: Dont know which plug in reply to RDAllison, 03-02-2007 16:00:27
The one under the engine is the oil drain. The other 3 are your transmission/hydraulic oil drain bolts.
RDAllison
03-02-2007 16:09:52
 Re: Dont know which plug in reply to StahlMaster, 03-02-2007 16:05:45
Thanks.
Dunk
03-02-2007 16:46:12
 Re: Dont know which plug in reply to RDAllison, 03-02-2007 16:09:52
Ummm, Good Luck!!
soundguy
03-02-2007 22:03:15
 Re: Dont know which plug in reply to Dunk, 03-02-2007 16:46:12
I'll say... ( wow! )
Soundguy
dan hill
03-03-2007 01:46:39
 Re: Dont know which plug in reply to soundguy, 03-02-2007 22:03:15
I used to help out in my FIL small engine shop.He gave me a mower to fix.A do it yur self fellow had tried to change the oil in a B&S engine.He locked on to the cam shaft boss with his vise grips and twisted it off.He couldnt understand why he needed a new base on the engine.I fear for this tractor.
Ross Pugh(NC)
03-03-2007 06:34:46
 Re: Dont know which plug in reply to dan hill, 03-03-2007 01:46:39
Me too, Dan. I think the best thing he can do is wait until he gets a FO-4 manual and reads thru ssome of it before using a wrench on anything.
soundguy
03-03-2007 22:27:06
 Re: Dont know which plug in reply to Ross Pugh(NC), 03-03-2007 06:34:46
I'd go one step further... Wait for the fo-4, and then call someone over to help him.. His chances for success will more than double..
Soundguy
Lance in Brenham, TX
03-03-2007 06:13:32
That's harsh Dan, at least he's asking questions.
soundguy
03-03-2007 22:29:07
 Re: Dont know which plug in reply to Lance in Brenham, TX, 03-03-2007 06:13:32
Yes.. it is good that he is asking questions.. but i also don't think it is harsh...
It doesn't take much to figure out that the only plug in the oil pan is where you drain the oil, vs the plug in the tranny which he identified, or the plug under the rear, which he also identified.
Soundguy
