Mistake?
premie farmer
03-03-2007 16:14:48
Hey I think I may have goofed the last time I used my 52 8N. I knew it was going to sit for awhile before I used it again so I took the 6 volt battery out so I could keep it inside nice and warm. While looking for the key the other day after two weeks sitting I couldn't find it. I went out to see if I could just jump the switch to get the old girl going to scrape the drive. I found the key in the ignition in the ON position. Apparently after shut down last time for some unknown reason I turned the key up after the engine quit then pulled the battery.
Question did I mess anything up in doing this. The old girl won't start now just drains the battery turning the starter?
gahorN
03-03-2007 21:29:33
 Re: Mistake? in reply to premie farmer, 03-03-2007 16:14:48
Looks like you temporarily damaged the Dunk. (grin)
old
03-03-2007 18:30:33
No battery no hurt to any thing,but your problem is most likely the points need cleaned or replaces since sitting does funny things to the points but thats also part of life and how things work. Clean or replace the points and you should be up and running again. Plus being a side mount the coils don't burn out as easy but since you pulled the battery the coil could not burn out on you because there was no power going to it any how
maplehillfrm,pat
03-03-2007 17:15:13
if you pulled the battery at the same time you left the key on,, there is no way that there is any connection in the nonstarting tractor,,,,unless you left the key on and then a few hours later decided to take the battery out giving the points or the coil a chance to burn,
Tom N MS
03-03-2007 16:48:38
What am I missing that Dunk and others are seeing? Did you leave the key on but you went ahead then and pulled the battery out? If this is the case then nothing was hurt by leaving the key on..
Dunk
03-03-2007 17:44:35
 Re: Mistake? in reply to Tom N MS, 03-03-2007 16:48:38
No doubt!!
I am a tad off my rocker tonight.
Yall keep an eye on me!!
Dunk
03-03-2007 17:49:41
 Re: Mistake? in reply to Dunk, 03-03-2007 17:44:35
I thank it waz a trick question to start with!!
LMAO!!
Yall did a VERY good call.
Whiskey sir?
Err, I don't mind if I do.
That will be $4 sir.
Jest put it on my tab.
Yes sir..
Tom N MS
03-03-2007 16:48:09
What am I missing that Dunk and others are seeing? Did you leabve the key on but you went ahead and pulled the battery out? If this is the case then nothing was hurt by leaving the key on..
Dunk
03-03-2007 16:34:28
Probably damaged the coil.
crazy8
03-03-2007 16:21:56
you may have burnt the points.
