92 fard tractor
allen45
03-05-2007 17:15:58
can someone tell me what tractor i have dont know if its a 2n or 9n here is the serial number from the motor block 9n133738
Older
03-06-2007 09:30:16
 Re: 92 fard tractor in reply to allen45, 03-05-2007 17:15:58
Dell, while your statement that all N engines are interchangeable is mostly true, there is an exception. And that is that the side mount blocks are not 100% interchangeable with the front mount blocks because there are bosses on the drivers (generator) side of the side mounts that are for the mounting of the gennys on those engines which are not there on the front mount blocks. And while you can use a side mount block with all the front mount accessories, the front mount blocks can not be used with the side mount accessories. Simple Eh?
Ntoxicated
03-05-2007 19:25:22
 Re: 2n ford tractor in reply to allen45, 03-05-2007 17:15:58
Allen , that serial number is for a 1943 2N model. Ask all the questions you want to and ignore the people that have ego problems . It is intuitively obvious who those people are.
Ntoxicated
03-05-2007 19:53:10
 Re: 2n ford tractor in reply to Ntoxicated, 03-05-2007 19:25:22
Sorry I looked at the list wrong , its a 1944 2N.
jwm
03-05-2007 18:51:28
Dell, what does "intuitively obvious" mean? Does it mean that it should be "intuitively obvious" to a graduate engineer, or does it mean "intuitively obvious" to a "Hayseed" who had to drop out of school in the 8th grade to help support the family? Respectfully, James
Ross Pugh(NC)
03-06-2007 05:21:31
 Re: 92 fard tractor?HEY EVERYBODY in reply to jwm, 03-05-2007 18:51:28
Hey everbody the troll has resurfaced!!
Bob Harvey
03-05-2007 18:59:28
 Re: 92 fard tractor in reply to jwm, 03-05-2007 18:51:28
Golly , gosh and heck...I think it means the same in MOST languages. As ' Popeye' once observed " Language is used more for communicatin' ..than any other "
Allen45
03-05-2007 17:52:48
 Re: 92 ford tractor in reply to allen45, 03-05-2007 17:15:58
Thank you very much for all of your help in finding out what kind of tractor I have. Thanks so much once again. Allen45
