Not getting any spark
RDAllison
03-06-2007 15:08:09
Hello,
I have a 1949 Ford 8n (front mount distributor).
It was given to me to fix-up. A 12 Volt conversion was installed but there did not appear to be any type of resistor added. We ( my dad and I) found that the coil was bad so we replaced it. But there is stil no spark from the plugs.
If any one has any suggestion it would be greatly appreciated.
Thanks
Tom N MS
03-07-2007 04:09:45
 Re: Not getting any spark in reply to RDAllison, 03-06-2007 15:08:09
At the same time you replace the points and condenser go ahead and install Dell's trick resistor--use with 12V coil. do not use regular ballast resistor-Use Radio Shack #271-13-1-- 1 ohm wirewound resistors 10 watt ....2 come in a pack, Wire them side by side--parallel..
john hunt
03-06-2007 16:42:51
first thing first turn the key on then check see if switch work . then start chase 12 volt wire with light see if all wire giving you light.. good luck
RP-40-9n
03-06-2007 16:38:10
if you have fire at the coil, but no fire at the points, try stertching the little spring pig tail at bottom of coil, new ones are sometime a little short, and do not make contact with the nut on the distributor. RP
Bob - MI
03-06-2007 16:11:22
Could be the ignition switch. Try a jumper wire and bypass the switch. I had one go out on me recently and it took $5.00 and a trip to Auto Zone to get me back running again.
Old is right about the points being suspect. You can try cleaning them first. Check the cap and rotor as well. Replacing these would be a great start to getting things eliminated as problems and it will give you a great baseline to work from. Not an expensive fix.
You should also consider getting a service manual. Available here on this site.
Welcome to the board and good luck with the tractor.
RDAllison
03-06-2007 17:05:12
 Re: Not getting any spark in reply to Bob - MI, 03-06-2007 16:11:22
I dont have the key to the tractor so im an already using a jumper wire. There is 10 volts to the top of the coil.
Thanks
old
03-06-2007 17:26:53
 Re: Not getting any spark in reply to RDAllison, 03-06-2007 17:05:12
You have volts to the coil so theres a good chance that its the points.
old
03-06-2007 15:21:28
It most likely needs new points and condenser. If the points are bad or dirty it will not have spark
