Order Ford 8N Parts Online
8n tractor
8ntractor
03-07-2007 09:09:21
I have started restoring an 1952 FORD 8n and have a problem where when the key is turned off the amp meter shows a discharge. If I disconnect the battery and then reconnect the battery the discharge is no longer shown. Can any one help! Thanks
KCM
03-07-2007 13:41:17
 Re: 8n tractor in reply to 8ntractor, 03-07-2007 09:09:21
Check to make sure you have the wiring connected correctly (Armature on generator to Armature on regulator, Field on generator to Field on regulator, Battery on regulator to ammeter). If everything is correct, then you have a faulty regulator (cutout sticking). Not all new parts are good out of the box.
n8tractor
03-07-2007 10:34:39
It is a 6 volt with a genny with a new V.R. I have replaced all the wireing and all gages.
souNdguy
03-07-2007 11:45:44
 Re: 8n tractor in reply to n8tractor, 03-07-2007 10:34:39
For S&G's Polarize the genny ( jumper bat to arm ) and see what happens... almost sounds like a cutout that is kicking open
Past that.. are you sure you have it wired correctly? When the key is off, there should be no current flowing thru that part of the circuit... so it must be something 'before' the key..e tc.. Or you have it wired wrong / non oem.
Soundguy
old
03-07-2007 11:45:31
Sounds like you may have a wire hooked up wrong some place.
old
03-07-2007 09:23:54
Need more info. Is it 6 volts or 12 volts?? Does it have a genny or alternator?? If it has a genny then most likely the V.R. is sticking on you. If an alternator then its probably wired wrong or bad
