BTW...
Poot
03-08-2007 10:10:13
I fergot to say that I checked all the filters... they are clear, & carb "pees" a good stream.
Dell (WA)
03-08-2007 10:56:39
 Re: BTW... in reply to Poot, 03-08-2007 10:10:13
Poot..... ..depending upon exact circumstances of operation, even a fully warmed up tractor can have "CARBURETOR ICING". This is internal and usually "invisable" and clogs up yer idlemix jets but NOT yer mainjet. It is definitely "weather-related" and a well known problem to light-aircraft pilots. Infact, most light aircraft (Pipers, Cessna's, etc) have a "Carb Heat" lever they pull ON approach to the idle'd-back engine carb don't ICE-UP and stall when the pilot needs power for a go-around. Heck, even yer belchfire-V8 has automatic carb heater from the exhaust manifold hidden under that big aircleaner..... ..Dell
Poot
03-08-2007 11:03:02
 Thanx, Dell. So.... in reply to Dell (WA), 03-08-2007 10:56:39
what do you recomend? Maybe some sorta gas treatment? It scared me when she started belchin' & phartin' like that! LOL
POOT
Dell (WA)
03-08-2007 11:25:24
 Re: Thanx, Dell. So.... in reply to Poot, 03-08-2007 11:03:02
Poot..... ..make an "oven" outta tin-foil and wrap from exhaust pipe around slanted carb tube. (tip: they are right next to each other) simple, eh?
or.....just wait for 1/2-hr for engine heat to de-ice yer carb throat. Itt'll be ok, mate.
The very act of "carburetion" sucks heat outta the air, the LOW PRESSURE behind the venturi needs heat to expand the vacuum created by the sucking of the pistons thru the intake valve.
Its MOISTURE IN AIR, not gastank. (altho gastank "Heat" or other panther pi$$ won't hurt ..... .Dell
