Thanx, Dell. So....
Poot
03-08-2007 11:03:02
what do you recomend? Maybe some sorta gas treatment? It scared me when she started belchin' & phartin' like that! LOL
POOT
Dell (WA)
03-08-2007 11:25:24
 Re: Thanx, Dell. So.... in reply to Poot, 03-08-2007 11:03:02
Poot..... ..make an "oven" outta tin-foil and wrap from exhaust pipe around slanted carb tube. (tip: they are right next to each other) simple, eh?
or.....just wait for 1/2-hr for engine heat to de-ice yer carb throat. Itt'll be ok, mate.
The very act of "carburetion" sucks heat outta the air, the LOW PRESSURE behind the venturi needs heat to expand the vacuum created by the sucking of the pistons thru the intake valve.
Its MOISTURE IN AIR, not gastank. (altho gastank "Heat" or other panther pi$$ won't hurt ..... .Dell
