water in oil
9n again
03-11-2007 13:22:52
Howdy, IChecked the oil on my 9N and it has either water or antifreeze in the oil. I had jsut change the oil a few mounths back. Any ideas
Thanks
Ross Pugh(NC)
03-11-2007 15:18:57
 Re: water in oil in reply to 9n again, 03-11-2007 13:22:52
Hello,9n. What ye are seeing in the oil is probably just moisture from running the engine just enuf to get moisture build upin the oil. These engines need to be brought to a good operating temperature each time ye start it ir this will happen. Ye oil will get milky looking and ye oil fill cap will get white gunk buildup in it. I* have had this happen and so has about everybody that has a N and does not run it to full operating temperature every time it is started. Most likely ye do not have a leak but ye could have a leaking head gasket. Run a wet and dry compression test and post the results and we can help ye decide if anything else may be wrong.
