Paint Removal on Tires
8N'r--WI
03-13-2007 11:11:54
Hi All----previous owner of my 49 8N tried touching up surface rust areas on the rear wheels to get it "seller" ready.
Unfortunately, he neglected to mask the brand new tires very well, and there is a nice "mist" covering of Ford Gray paint all over the sides of the tires.
Does anyone have an idea of what I could use to get the paint off without ruining the tires?
Thanks---Tim
Ozlander
03-13-2007 18:38:16
 Re: Paint Removal on Tires in reply to 8N'r--WI, 03-13-2007 11:11:54
On reason to remove the paint. Just go use the tractor, run your bush hog, do some dirt work, plow and the paint will be gone.
Bob Harvey
03-13-2007 17:14:26
Lacquer thinner and rags.
john hunt
03-13-2007 17:01:27
high pressure washer and smiply green degreaser and a green srubie with alot elbow grease or buy some new tire .... which is easyie way ....
HCooke
03-13-2007 16:56:16
Black tire paint (Miller's tires - e-bay) works pretty well.
D Masury
03-13-2007 16:01:34
I heard a long time ago that WD-40 does a good job at removing over spray..... I bet you got a can laying around somewhere.... a soft scruffy pad and Wd-40....along with a beer sounds like the way to go at it.
DHM
Taylor
03-13-2007 15:52:02
One more, and least attractive idea, you could swap the tires from side to side. Not the wheels just the tires. That would put the overspray on the inside where it would be less noticeable. If you scuff the tires too much it may still be necessary.
Chad OH
03-13-2007 12:41:08
Mine wheels were terrible when I got it.
Like it was done in the wind or something.
I put the brush attachment on my drill and it took it right off and beat scrubbing by hand.
Hope this helps,
Chad
8N'r--WI
03-13-2007 14:53:22
 Re: Paint Removal on Tires in reply to Chad OH, 03-13-2007 12:41:08
Thanks, Sounds like a good idea---what kind of brush attachment did you use?--Tim
Chad OH
03-13-2007 19:36:31
 Re: Paint Removal on Tires in reply to 8N'r--WI, 03-13-2007 14:53:22
Its the flat kind, looks kinda like a flower. (sorry for the bad description)
I had to run the drill front to back parallel with the tractor front to back so the side of the attachment hit the tire- make sense?
I didn't run it with heavy pressure against the tire - not that I was worried about scuffing it cause my tires have scuffs already, but it seemed to work better.
The drill I used was an old 12v Black and Decker that had seen better days, so it wasn't anything special.
Hope it works for ya if ya try it.
-Chad
souNdguy
03-13-2007 11:16:51
Just about any abrasive will scuff the tires, however i have had good luck with a plastic pot scrubby.. not the square fiberglass scratchy pads.. but the ones more like the things you take bugs off windoes and plastic noses of cars.
Most chemicals may mar the tire.
Last option is to wash real well with detergent.. then paint with tire black.
Soundguy
8N'r--WI
03-13-2007 12:00:07
 Re: Paint Removal on Tires in reply to souNdguy, 03-13-2007 11:16:51
Thanks Sounder---will try the plastic scrubby first---than the detergent---Tim
